bmp's not displayng correctly...
Noely71
Hi,
Whenever i put a bitmap as the texture map, it kind of shows it end ways. i.e. its just coloured lines in the wall. (as per attached image)[ATTACH]21787[/ATTACH]. i have tried rotating it all directions, flipping it. nothing seems to work. it does show atlleast the picture if i make the rotation relative to the screen... but ofcourse i need it relative to the object!
Any insight to what i'm doing wrong would be sweet!
Neil
are u using UVW mapping? if not apply the UVW mapping modifier from the modifier list, select box in the sub menu and change the u,v, & w values till u get ur desired size.
theres also a gizmo setting which u can alter to change the orientatin of the map.
hope this helps
cheers
