Guest versionseven Posted August 18, 2002 Share Posted August 18, 2002 I have no problems doing interior shots using radiosity(i use IES files of all the light fittings), but I am having diffuculty with exterior night shot. I currently use IE sky for the night ambient light but can't seem to get it to look rite. Can someone help me? Chan Link to comment Share on other sites More sharing options...
NenadK Posted August 20, 2002 Share Posted August 20, 2002 hi, chan this might get tricky -using skylight for evening shots- because you need to find the correct balance beetween the skylight and the artificial light inside the building. personally, i start with making interior lights work well, and then I would add a bit of skylight only if this is really necessary. if you could post an image of the problem, we could discuss in more details. cheers Link to comment Share on other sites More sharing options...
