Cesar R Posted January 26, 2003 Share Posted January 26, 2003 Does max 5 or viz 4 support HDRI? or is there a way? Link to comment Share on other sites More sharing options...
Jeff Mottle Posted January 26, 2003 Share Posted January 26, 2003 There was some discussion about this a few days ago. Check these links: http://www.cgarchitect.com/ubb/ultimatebb.php?ubb=get_topic;f=11;t=000104#000001 http://www.cgarchitect.com/ubb/ultimatebb.php?ubb=get_topic;f=26;t=000026#000003 Link to comment Share on other sites More sharing options...
Cesar R Posted January 26, 2003 Author Share Posted January 26, 2003 thanks Jeff Link to comment Share on other sites More sharing options...
ingo Posted January 27, 2003 Share Posted January 27, 2003 Well "supporting" is only that they can open the files, which they can. But AFAIK both rendering engines are only 32 bit, so they are not able to really use the advantage of the 128 Bit format. But i think we should take a close look at ILM's OpenEXR which is now open source and works fine with my first tests, i hope the software developers support this format soon so we are able to exchange these files between different softwares. Link to comment Share on other sites More sharing options...
abicalho Posted January 27, 2003 Share Posted January 27, 2003 The 3dsmax/VIZ renderer is 64 bits per pixel. You can output to PNG, RLA and RPF at such bit depth. Also, RPF, in MAX 5.1, allows you the option to save 32 bit float per channel. Alexander Link to comment Share on other sites More sharing options...
