Guest versionseven Posted September 9, 2002 Share Posted September 9, 2002 Is there any way to render a interior scene in Viz with 200 photometrics lights without crashing the computer. I need to use that many lights because we are doing a lighting study of the dome in a palace. Please advise. Thanks Link to comment Share on other sites More sharing options...
plastic Posted September 9, 2002 Share Posted September 9, 2002 define crash... probably you have not enough ram. you can increase the radiosity meshing size to reduce memory consumption. Link to comment Share on other sites More sharing options...
Guest versionseven Posted September 12, 2002 Share Posted September 12, 2002 There is no problem doing the radiosity calculation, but when I render the actual scene, it stops after rendering partially. Any advice? Link to comment Share on other sites More sharing options...
abicalho Posted September 12, 2002 Share Posted September 12, 2002 Choose Re-Use Direct Illumination in the Radiosity dialogue. That option will render the direct illumination from the Radiosity mesh and won't re-process shadows and lights. This will make the renderer more memory efficient, but you may lose precision on your shadows. Alexander | discreet Quality Engineer Link to comment Share on other sites More sharing options...
