ZulkarneyN Posted August 14, 2007 Share Posted August 14, 2007 i am experienced with acad but new at ADT, i ve acad architecture and drawing a project for assay with 4 floor. my ground floor and 3 same floor. when i view the exterior elevation ,north elevation it shows only one floor elevation its 300 cm height and its all.I dont see all building. i checked elevation drawing includes all floors but shows only one. my plans including "00 core" and "00 column" every floor has same core and columns.they can be seen at plans but elevations have problem... Link to comment Share on other sites More sharing options...
visualasylum Posted October 16, 2007 Share Posted October 16, 2007 the reason for this is, you have to understand how the level works, and how you align it so you don't run into problems. Order the Thomson book Autodesk Architecture 2008, it will help you understand levels. I hope to have helped you here. Link to comment Share on other sites More sharing options...
