(Dwg exporting Into 3DMax) Generate Coordinates Problem
tarek.saade
Hello Everyone,
Welcome For any idea or advice or test could help Thank you.
I have this problem:
I made model of street S Shape in two programs ( Autocad & 3d studio max).
I want to apply my maps (street-2.jpg+street2b.jpg) on Street model.
When am using the model which i did directly in max I dont have any Problem with map because the map follows the shape of my street ( S-shape) and it is looks very good.( Foto-2)
But
When am using the autocad model of street exported in 3Dmax using ( import function in max with Generate Coordinate parameter) or ( Export As .3ds in Autocad) I have problem to apply the map and let it fits the shape of street ( Foto-1).
which i need is to apply the maps on The Autocad Model to Looks in the same way on 3dmax model in 3Dstudio max !!!
Any Idea Welcome!!!!
I attached Every File You need!!
Regards
I have also faced these type of problem lot of times. Model made in autocad does not come with a proper uvw map. So, its always good to have the road modeled in 3dsmax using loft tool. Loft maintains the uvw coordinate of the model and you can also use the autocad drawing line as path profile in loft. I hope this helps you little bit. Dont hesitate to ask if you have some more doubt.
