Guest nazcaLine Posted August 19, 2007 Share Posted August 19, 2007 ok, let's suppose i have a spline with a complex path. now i activate the renderable spline option, and assign a thickness to the spline, so i have something like a pipe or a cable. but now i want it to be thinner in a extreme and thicker in the other, i mean a constant change in thickness uniformly through all the spline. what can i do? any suggestions or ideas?? Eduardo Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted August 19, 2007 Share Posted August 19, 2007 I think you're looking for Loft. It let's you change the profile along the spline, so you can do not only a pipe that gets thinner in one end, but you can also make a rectangular section become circular. Very handy. Link to comment Share on other sites More sharing options...
Guest nazcaLine Posted August 20, 2007 Share Posted August 20, 2007 well, my idea was to AVOID loft... it's too complicated...what i had in mind was this modifier (i think) that i saw in a tutorial i can't find now...it used a graph to deform the object along the path, you could apply bezier control points, etc. i'm looking for it in the modifier drop down list and nothing... Eduardo Link to comment Share on other sites More sharing options...
jucaro Posted August 21, 2007 Share Posted August 21, 2007 well, my idea was to AVOID loft... it's too complicated...what i had in mind was this modifier (i think) that i saw in a tutorial i can't find now...it used a graph to deform the object along the path, you could apply bezier control points, etc. i'm looking for it in the modifier drop down list and nothing... Eduardo Thats still loft with the instanced splines. Loft is pretty much straight forward. Link to comment Share on other sites More sharing options...
