Realistic Glass Material using default scanline renderer
rishmantrijo
Guest nazcaLine
you can use the "Glass Clear" material that comes with the Max libraries (Raytraced 01) OR you can check ted boardman's tutorial about Architectural Glass here in cg architect.(Resources>Feauterd articles>Ted Boardman)
Eduardo
Thanks Eduardo! it helped me a lot of easily finding the material that i need in my projects. & 1 more thing is it possible of using a material that comes from mental ray render engine & adopt it & use in vray renderer or vice versa? Is there a possibility of doing so? 'coz i tried using a mental ray glass material & render it in vray, it dosnt work.. Any solutions?
