PAWUK Posted August 23, 2007 Share Posted August 23, 2007 Hi Been working on a small test project something I modelled in autocad imported to max and rendered in vray 1.5. Curved glass takes up the refraction fog colour, as you can see in the attached image in this case green (still in early stages of devlopment) The flat glass panels along the balcony and windows have the same material applied. Any Idears Link to comment Share on other sites More sharing options...
Stephen Thomas Posted August 24, 2007 Share Posted August 24, 2007 Bring your refraction level down from 255 to about 240, then choose a light green (slightly more towards blue than you have here) colour and fog value of around 0.05 should be sufficient. Play around with these values if you like but that should give a good starting point. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted August 24, 2007 Share Posted August 24, 2007 Also you may need to up your max depth on refractions and check your IOR (should be 1.5) to avoid the distortion you are getting. Link to comment Share on other sites More sharing options...
PAWUK Posted August 24, 2007 Author Share Posted August 24, 2007 Hi stef tried all that but it didnt solve the problem, finally increased the fog bias in refractions that seemed to sort it out. Cheers Paul Link to comment Share on other sites More sharing options...
