tricota Posted August 24, 2007 Share Posted August 24, 2007 Hi, i need to add a new folder path on many "network render slaves PC" Like we did in the past using 3dsmax.ini where you could change 3dmax setting using a text file. per example you add a line like this to add a new path [bitmap] Dir1=\\yourserver\yourtexturefolder I found out it doesn't exist anymore. How can I do it in Max9 without opening max and add the path via "configure user paths". I cannot access those render slaves because I didn't activate them. So I can't open Max to add the path, so I need to do it via text file configuration. Any Help Please more than welcome. Thanks Trico Link to comment Share on other sites More sharing options...
tricota Posted September 4, 2007 Author Share Posted September 4, 2007 Hi, I found out there is a 3dsmax.ini topic in the "3ds max reference" at "Getting STarted with 3ds max" sub menu. But I think this is old and they didn't update the max9 reference. any help please? thanks Link to comment Share on other sites More sharing options...
