PGD Posted August 24, 2007 Share Posted August 24, 2007 Hi folks I just built a new machine and have XP 64 Pro installed, thing is its got 4GB of RAM in there but when I go to System Properties it says 3.25GB of RAM Why doesnt it say 4GB? Is this normal? Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted August 24, 2007 Share Posted August 24, 2007 What mobo? Link to comment Share on other sites More sharing options...
PGD Posted August 24, 2007 Author Share Posted August 24, 2007 ASUS P5W DH Deluxe SKT 775 dual-core Core2Duo Conroe ready Crossfire 8channel audio ATX... Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted August 24, 2007 Share Posted August 24, 2007 Did you look at bios settings? XP x64 should see all 4GB, are you shore it is x64? Because on regular x32 it is 3.25GB to see. Link to comment Share on other sites More sharing options...
PGD Posted August 28, 2007 Author Share Posted August 28, 2007 Bios settings? When where? I can go into system and it'll say XP64, then lower down on the same screen it says 3.25GB of RAM. So as far as I can tell its XP64 thats running (start-up screen says 64 on too) But I'm confused about the RAM. Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted August 28, 2007 Share Posted August 28, 2007 Press DEL (or F2 during) on the keyboard the post screen while PC is booting Link to comment Share on other sites More sharing options...
PGD Posted August 28, 2007 Author Share Posted August 28, 2007 Ok, so when I do that what should I look for or change? What should I see? Never done that before and I'm hopeless at IT Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted August 28, 2007 Share Posted August 28, 2007 ^thats a problem What motherboard do you use? Do you have a manual for it? You should for the settings like "ram etc...." But its hardly to help this way Link to comment Share on other sites More sharing options...
PGD Posted August 28, 2007 Author Share Posted August 28, 2007 Ok then I'll get the manual out and look into it deeper some time. Thanks for the help so far Link to comment Share on other sites More sharing options...
Ernest Burden III Posted August 28, 2007 Share Posted August 28, 2007 So as far as I can tell its XP64 thats running (start-up screen says 64 on too) But I'm confused about the RAM. I have a similar problem. I just started up a new workstation which is supposed to have XP-64 but the startup just said XP. I thought that was odd, but have never used XP-64 before so what do I know? It seems that Boxx put in regular XP. I have 8GB RAM installed (I opened the case to check), but of course the machine can only see the first 3GB. Well this is annoying! Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted August 28, 2007 Share Posted August 28, 2007 ^ you must go on XP x64, re install or call them to do that 8GB is very very very usefull on x64 Link to comment Share on other sites More sharing options...
