djohnson129 Posted August 25, 2007 Share Posted August 25, 2007 ....or the best way. I just model them using a plane and the FFD modifier to squinch it up and then pull out some wrinkles. Or if its a more detailed wrinkled curtain I'll model it in Zbrush and bring it to Max. Just wondering how you guys make curtains? -David Link to comment Share on other sites More sharing options...
aaron-cds Posted August 25, 2007 Share Posted August 25, 2007 I create a plane with several vertical segments. I convert it to a edit-poly then apply a noise modifier. Lastly, I apply a turbo smooth modifier. If the camera will be really close to the curtains I'll apply a shell modifier. If the curtians will be tied off in the middle, I use a ffd modifier. Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted August 25, 2007 Share Posted August 25, 2007 I usually use reactor to animate an opening curtain and then take the best frame and use it. Link to comment Share on other sites More sharing options...
Sawyer Posted August 25, 2007 Share Posted August 25, 2007 Ok Rick why do you use reactor over the cloth modifier? I have been using cloth and I really like it but its been so long since I played with reactor I honestly can't say which one is better. Link to comment Share on other sites More sharing options...
djohnson129 Posted August 26, 2007 Author Share Posted August 26, 2007 Smoothing a noise modifier sounds like a good idea. I'll have to try that. How about the shader for the curtain? I've been using the thin geometry option. Got any other favorites? Link to comment Share on other sites More sharing options...
