wierd interpretations of screens and louvers
chadsmith
I've done some tests with MR sampling settings before.
I found that these settings (in the Renderer tab of the Render Scene dialog when MR is the active renderer):
Samples per Pixel: Min=1 Max=16
Contrast: Spatial: RGBA all = 0.1
gave results indistinguishable from the same scene rendered with these settings:
Contrast: Spatial: RGBA all = 0.051 (the default)
The rendering times for each setting with the test scene were 51 and 67 seconds respectively.
I tried these settings too:
Samples per Pixel: Min=1/4 Max=16
...and got a rendering time of 33 seconds. However, there was some aliasing across edges of lowish contrast, but I had to scrutinise the image a bit to find it. I gather what the contrast setting does is set a contrast threshold for AA: adjacent edges that fall within this contrast tolerance (ie: are not significantly lighter or darker than one another) are sampled to a lesser extent, saving rendering time.
