Andrew Roane Posted August 28, 2007 Share Posted August 28, 2007 I've been using Max w/ Vray for about two years, and I recently downloaded the free version of Maya to play around with (Maya 8.5 PLE). I also downloaded the Vray for Maya 8.5 beta from ChaosGroup. Now I just can't seem to figure out how to assign Vray as my renderer of choice. Does anyone know if the PLE version of Maya is compatible with the Vray demo, and if so, how do you assign it as the default renderer after it has been installed? Thanks. Link to comment Share on other sites More sharing options...
manta Posted August 29, 2007 Share Posted August 29, 2007 well, I'm not sure if you're gonna be able to use it, but if you are...go to the plugin manager and activate it there, then it should work, like I said, if its even in there... Link to comment Share on other sites More sharing options...
Andrew Roane Posted September 1, 2007 Author Share Posted September 1, 2007 Thanks, I'll try that. Link to comment Share on other sites More sharing options...
