can't open a scene, how to reset settings?
d7man2000
How can I reset settings of 3ds Max?
I can't open any scene.
I checked Memory Usage under Windows Task Manager and I noticed that Max memory for Max gets to a certain value and nothing above, usually memory increased as scene is opened. In this case memory stops and Max crashes.
I don't know what happened, I never had this issue before.
I didn't change anything either.
I also use Vray
Any advice would be greatly appreciated
Kris.
no that's not it, i tried all of them, software,opengl,direct3d
In Windows Task Manager, maximum memory usage is 169 MB, i don't know why it stops, it should go up, because it doesn't , computer crashes, I don't know if it software or hardware or what
it drives me crazy because i can open a scene on a different computer
it's definitely all scenes not just one?
i've had problems with textures corrupting max and have had to move the texture to another directory to stop it crashing...
other than that, try saving the max file as a 3ds on another computer then import it on the problem computer
failing that... are you running different versions of max on each computer?
I have it working
I did something what I thought wouldn't work
I copied whole folder 3dsMax 9 from a computer that worked to computer that crashed and to my surprise everything loaded fine.
nothing crashes anymore
it was something in a program that got corrupted.
I don't know what because I didn't change anything
thanks guys for feedback.
