jccloutier Posted September 3, 2007 Share Posted September 3, 2007 I have an animation in max that is 2700 frames. I created a cloth modifier to some pendants blowing in the wind but the movement stops after 100 frames. Can I loop the 100 or make it go the 2700? Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted September 3, 2007 Share Posted September 3, 2007 Are you using Reactor? If so, go to the Utilities tab, choose reactor and, under Animation, set the # of frames you want. Link to comment Share on other sites More sharing options...
jccloutier Posted September 3, 2007 Author Share Posted September 3, 2007 Are you using Reactor? If so, go to the Utilities tab, choose reactor and, under Animation, set the # of frames you want. That was it, you're the man. Thanks. Link to comment Share on other sites More sharing options...
