sanjay_chaphekar Posted September 4, 2007 Share Posted September 4, 2007 hi, There is one problem with vray i have encountered during rendering exteriors. If the room is not lit from inside, it is difficult to get the glass material working. And we have to deal with it in photoshop. Moreover for long we have been using lines with thickness for making window glasses. But vray requires solid box to simulate the same. I had posted this problem in finished work section but i did not get any response so i am posting it here. thanx, sanjay chaphekar Link to comment Share on other sites More sharing options...
AlNe Posted September 4, 2007 Share Posted September 4, 2007 Turn off refraction, increase reflection (falloff map or just Fresnel checkbox) and don`t forget about Enviroment map (for reflection). Link to comment Share on other sites More sharing options...
chiquito Posted September 4, 2007 Share Posted September 4, 2007 In adition to alexanders post, you could try a fresnel fall off on the refraction map, and give it a try. Another option could be to place a white reflecting plane behind the windows, with render unchecked in properties. you could use that reflection to light up your glass. Link to comment Share on other sites More sharing options...
sanjay_chaphekar Posted September 4, 2007 Author Share Posted September 4, 2007 thank you very much for these suggestions. Link to comment Share on other sites More sharing options...
kts_pc2 Posted January 24, 2010 Share Posted January 24, 2010 Thanks very much for teaching Link to comment Share on other sites More sharing options...
azizdesign Posted January 24, 2010 Share Posted January 24, 2010 I am currently working on the exterior glass this is the first forum where I could find a correct answer thank you very much Link to comment Share on other sites More sharing options...
