vizwhiz Posted September 4, 2007 Share Posted September 4, 2007 http://www.calvin.edu/~adams/research/microwulf/ so what The hell happened To Beowulf? where wulf? quote below is direct from url page (entirely) Microwulf is a personal, portable Beowulf cluster, providing over 26 Gflops of measured performance, for less than $2500. Its dimensions are just 11" x 12" x 17", making it small enough to fit on one's desktop or in a suitcase. Microwulf was designed and built by Calvin CS professor Joel Adams and senior Tim Brom. For more details, click one of the links below: DesignHardware ManifestSystem Configuration NotesPhotosPerformancePrice/Performance RatioPower/Performance RatioUsesCluster Monkey articleUpdate: As of Aug 1, 2007, Microwulf can be built for $1256, improving its price/performance ratio to less than $48/Gflop. See the Cluster Monkey article above for the details. ok, just read This briefly, not sure about OS and video cards &/or monitor, but it does look like low cost computing possibility ** if anyone else reads This and can add more info: wiki This Thread and maybe we can build a low cost rendering farm in The background Thanks randy Link to comment Share on other sites More sharing options...
vizwhiz Posted September 4, 2007 Author Share Posted September 4, 2007 1st edit http://www.clustermonkey.net//content/view/211/1/ i am reading The ClusterMonkey article, The following seems To be important For our CPUs, we chose AMD Athlon 64 X2 3800 AM2+ CPUs. At $165 each in January 2007, these 2.0 GHz dual-core CPUs were the most cost-efficient CPUs we could find. (They are even cheaper now - about $65.00 on 8/1/07). To keep the size as small as possible we chose MSI Micro-ATX motherboards. These boards are fairly small (9.6" by 8.2") and have an AM2 socket that supports AMD's multicore Athlon CPUs. More precisely, we used dual-core Athlon64 CPUs to build an 8-core cluster, but we could replace those CPUs with AMD quad-core Athlon64 CPUs and have a 16-core cluster, without changing anything else in the system! will add more info as Time goes by i called The author of This project, hoping To hear back from him ** Thanks randy Link to comment Share on other sites More sharing options...
AJLynn Posted September 4, 2007 Share Posted September 4, 2007 It's a cluster of 4 dual-core 2.0GHz boxes. You need to run cluster/farm software. You can probably get much better performance out of an extremely overclocked single Q6600 box. Link to comment Share on other sites More sharing options...
