Radiosity and Washed out textures. Y?
Coreyhrpr
Are you NOT using advanced lighting material overide map? It lets you control the bounce of light and surface behaviour of your materials. You might also want to enable exposure control in you environment setting.
Posting a picture of your preliminary render might help us help you more. :)
coreyhrpr,
A couple possibilities-
The wood parquay map seems a bit light and washed out to start with. If possible try to adjust the levels in photoshop for example. Darken it up and drive up the saturation, I've had some luck with this method.
Try the color map adjustments if rgb and output levels don't work.
Are the lights themselves adding to the washed out flooring. The wood seems really orange tinted. Light color? To much light energy onto the flooring, in contrast with the atrium lit area?
Try the increasing contrast and or midtones in the logarithmic exposure controls or exposure value in the linear exposure controls.
Hope this is helpful. I have used these tips quite a bit with good results.
rgrds
WDA
I've found this problem to be mostly a function of the exposure control. Try these settings and let me know if they help.
Set Exposure Control to Logarithmic. Change Physical Scale to match the candela output of your strongest ies light, in an interior usually about 2000. Most importantly check the box "Affect Indirect Only" and uncheck both Daylight and Exterior.
Colin
Thank for your help -
I did a lot of testing, tried the Affect Indirect Only (the problem with the washed out textures was fixed but I lost my shadows from my lighting).
To make a long story short I decided to play with the material itself. I found an exceptable fix. What I did was;
created a new material, set it to Oren Nayar Blin, put my texture map (which is the carpet jpg) in the diffuse slot, and then I made an instance in the DIFFUSE LEVEL slot. Both set to 100%. It kept the color from getting washed out and I had shadows.
I'm was a long time user of Lightscape. RIP. I miss the glass material, the display raw material option, and the easy reflections.
anyways, thanks for your help guys....
Hope someone learns something from my troubles :)
if you want to use viz/max radiosity you have to ignore the mtl editor preview!!!!!
If you make everything right, the mtlpreview will be very dark. The reason is that you should not have more than 40-60% Reflectance for a normal material. ..so a white wall will be 60% gray and your floors texture will have an outputamount value will not have more than 0,6.
every value above will give you what you get.
