martin walker Posted September 9, 2007 Share Posted September 9, 2007 Im getting bizarre rendering results. This is definitely NOT a GI problem or a shadow problem as I get the same result with shadows off and GI off. The model is big, (400m across) but Ive dozens off these before and no problem. The model was created with sketchup...dont know if that has any bearing any help greatly appreciated btw Im using vray 1.5 rc 3 Link to comment Share on other sites More sharing options...
njoco2 Posted September 9, 2007 Share Posted September 9, 2007 A week ago I was given some sketch up files to render in max/vray. I had the same problem when I rendered the models. After an hour of turning layers on and off and doing test renders I moved the model up/z-axis just a little bit. It did the trick. I hope this works for you too. cheers Link to comment Share on other sites More sharing options...
manta Posted September 9, 2007 Share Posted September 9, 2007 I was going to say sort of the same thing...make sure its not too far away from the origin...that can sometimes screw things up... Link to comment Share on other sites More sharing options...
martin walker Posted September 9, 2007 Author Share Posted September 9, 2007 thanks Jovica, William I will try that now Link to comment Share on other sites More sharing options...
Horhe Posted September 9, 2007 Share Posted September 9, 2007 Seems like the plane is overlapping with another plane or it has no thickness. Probably has a extrude value of 0.00. Either 1. Give it some extrusion 2. Make sure its not overlapping with another plane 3. Under the global switches tab set the secondary ray bias to 0.001 Hope that helps Link to comment Share on other sites More sharing options...
martin walker Posted September 10, 2007 Author Share Posted September 10, 2007 njoco2 said: A week ago I was given some sketch up files to render in max/vray. I had the same problem when I rendered the models. After an hour of turning layers on and off and doing test renders I moved the model up/z-axis just a little bit. It did the trick. I hope this works for you too. cheers yeah...this did the job.....very strange.. thankyou very much !!! Link to comment Share on other sites More sharing options...
