ZFact Posted September 10, 2007 Share Posted September 10, 2007 Hi; Why does Cinema not include a snaps tool like most of the other modelling apps have? Cheers Link to comment Share on other sites More sharing options...
edub Posted September 10, 2007 Share Posted September 10, 2007 C4D does have snaps. you can access them with the "p" hotkey during modeling, and they also become active in the Attributes panel (3rd tab) when you activate the move, scale or rotate tool. Link to comment Share on other sites More sharing options...
ZFact Posted September 12, 2007 Author Share Posted September 12, 2007 C4D does have snaps. you can access them with the "p" hotkey during modeling, and they also become active in the Attributes panel (3rd tab) when you activate the move, scale or rotate tool. cheers how do you snap to imported line work? Paul Link to comment Share on other sites More sharing options...
edub Posted September 12, 2007 Share Posted September 12, 2007 Admittedly, the C4D snaps could use an overhaul. Your best bet is to use the 2.5D snap (constrains your points to the reference plane, regardless of where you snap to in depth). I've successfully used imported illustrator (v.8) linework, snapping to endpoints, and sometimes midpoints, as necessary. It takes a little time to get comfortable with, but works fairly well. Link to comment Share on other sites More sharing options...
ZFact Posted September 16, 2007 Author Share Posted September 16, 2007 thanks erik Link to comment Share on other sites More sharing options...
