Do you use the AEC walls/windows/doors?
robkar97
Hi!
I wonder of a professional visualiser like you guys at this forum use the AEC features of MAX?
I both like them and find them frustrating and very hard to edit... :confused:
The parametric approach to adding windows and doors is useful if the client changes his mind and want the model updated.
Is box modelling or boolean modeling better in genereal?
Any input on this would be great.
Sincerely,
Robert Karlsson
No AEC for walls.
Railing & Stairs can be done.
Use standard modelling technique's
Then use linked X-form to use it's feature.
Select the vertices that make the opening --> then select Linked X-form and Pick the window.
When you move the window the opening will follow.
-- that's the way I like it! --
we sometimes use the railings as windows if we need something fast. you set them to solid panel and then make the panel material glass. It's good if you need to divide a long expanse of glass evenly and you don't have a drawing. I only use the stairs for circular staircases. otherwise not really.
handle with care!!!
i cant specify all pros & cons but trust me, ur better off without them.
i used them once for a model and each time i closed & re-opened the file all the windows moved. very frustrating and not-understandable as oppsed to other more intelligent software.
