Paul Welch Posted September 13, 2007 Share Posted September 13, 2007 I am having problems with rendering. The maps in my scene sometimes do not render out and render in grey . I am hoping someone can help me? It is becoming very frustrating and I cant figure it out. Attached is an example the first jpeg shows the problem the picture has rendered out grey the second jpeg shows the map rendering ok. Sometimes a bit of the map renders then it turns grey!! Every now and then the scenes render out fine!!! Any help would be much appreciated. Link to comment Share on other sites More sharing options...
BrianKitts Posted September 13, 2007 Share Posted September 13, 2007 where are the bitmap files located.... are they local or on a network? if it's a network is your cable loose.... or is the network connected? grey maps normally mean vray was unable to locate the bitmap for some reason or other Link to comment Share on other sites More sharing options...
Aaron2004 Posted September 13, 2007 Share Posted September 13, 2007 MMM...well, this wouldn't account for the fact that it renders out fine every now and then, but do you have your diffuse map turned on? Sometime the check box gets unchecked for me and I don't realize it. You can tell by the diffuse check box under the maps section of the material editor, or a small 'm' instead of a large 'M' next to your diffuse color swatch. Link to comment Share on other sites More sharing options...
Ray Posted September 13, 2007 Share Posted September 13, 2007 Are you using viz and the 1.47 build of vray? Link to comment Share on other sites More sharing options...
Paul Welch Posted September 13, 2007 Author Share Posted September 13, 2007 I am using viz 2007 and 1.47 of vray Link to comment Share on other sites More sharing options...
Ray Posted September 13, 2007 Share Posted September 13, 2007 There's a known bug with viz and 1.47. Either upgrade to 1.5 or downgrade to 1.46. Link to comment Share on other sites More sharing options...
Paul Welch Posted September 13, 2007 Author Share Posted September 13, 2007 Cheers ray your a diamond! Link to comment Share on other sites More sharing options...
