Devin Johnston Posted September 13, 2007 Share Posted September 13, 2007 I know nothing about MAXScript other than Max uses it, and i've found a freeware plugin that I need to add network rendering to and I have no idea how to do it. Can someone give me a hand? Link to comment Share on other sites More sharing options...
manta Posted September 13, 2007 Share Posted September 13, 2007 And the plugin is.............. Link to comment Share on other sites More sharing options...
Devin Johnston Posted September 13, 2007 Author Share Posted September 13, 2007 It's a stereograph plugin that lets you create stereographic 3D images, this is the web site, I would have asked the maker but there's no contact info on their site. http://www.burningpixel.com/Max/StereoG.htm The plugin works great but to use it in animations I really need to be able to network render with it. Link to comment Share on other sites More sharing options...
manta Posted September 14, 2007 Share Posted September 14, 2007 did you try installing it on all the render nodes...or at least a couple to test it out.... Link to comment Share on other sites More sharing options...
jucaro Posted September 14, 2007 Share Posted September 14, 2007 you can also render the left and right cameras, composite it in AE or whichever you are using, shift the cyan channel of either the right or left camera, and you will get the same effect. Link to comment Share on other sites More sharing options...
chiquito Posted September 14, 2007 Share Posted September 14, 2007 Check for a plug in called "cross eye mary", does the same, its free, intall hasle free. Link to comment Share on other sites More sharing options...
Devin Johnston Posted September 14, 2007 Author Share Posted September 14, 2007 Thanks Martin I'll check it out! Link to comment Share on other sites More sharing options...
