help! weird lighting problem!
dpcaltdcah
If I am using a precalculated irradience map and I render the same exact frame two times in a row without changing anything anyone know why the lighting would look different? every computer in the office is coming out with something different so it looks like the light is flickering.
I've attached an example of a region that I rendered twice using the same irradience map from file on the same machine. I did not change a single thing between renders...
I think you should use secondary bounces (light cache) it makes the calculation more adaptative and avoid flickering.... and every 10 frames? is the camara moving fast? If you increase the nth value, you will get more softness..... and using light cache your imap will calculate really faster....
