ctk111 Posted September 14, 2007 Share Posted September 14, 2007 I'm trying to render out a gravel road that looks somewhat believable, but I'm not having any luck. It always looks too flat even with a bump map. I'm going to try a displacement modifier, but I'm worried about render times. Any suggestions are appreciated. Link to comment Share on other sites More sharing options...
Aaron2004 Posted September 14, 2007 Share Posted September 14, 2007 I would say your best bet would be displacement (if you are going to be up close). It shouldn't be that bad with render times. You COULD scatter geometry of the gravel...but that would hit your render times harder than displacement. Plus it would just be a bear to do. Link to comment Share on other sites More sharing options...
Nic H Posted September 15, 2007 Share Posted September 15, 2007 I reckon bump mapping should suffice depending on how close you get to it. Id turn of bitmap blur in the diffuse for a start if you haven't already. The most important bit will be having a high quality large diffuse map that tiles well, then you can create your bump from that. Have you got a screen shot? Using a blend material between 2 textures could be a good idea as well Link to comment Share on other sites More sharing options...
RodT Posted September 15, 2007 Share Posted September 15, 2007 try blending as nicnic suggested, include the "travel lanes" as well, perhaps two objects with differing displacement? I'm curious to see what you come up with, share it when you're done? good luck Link to comment Share on other sites More sharing options...
