crushdrive Posted September 15, 2007 Share Posted September 15, 2007 Hello everyone, Please can anyone help me about importing curve, arc lines & curve solids to 3Dmaxs? Well here is the scenario i prepare my model in AutoCad with curve walls & profiles (usually perfect as i wanted) then when i import to 3D maxs i get a distorted curved. I've tried all options i used on the best of my knowledge but i think i'm missing something. Pls pls pls i want to move on but this problem keep on coming back need you help. Thank you for advance hepl. Crush Link to comment Share on other sites More sharing options...
PAWUK Posted September 15, 2007 Share Posted September 15, 2007 Hi I had a similar problem solved it by importing as a legacy dwg, sure theres a better way but got me out of the problem so didnt dig any deaper Link to comment Share on other sites More sharing options...
Brian Smith Posted September 15, 2007 Share Posted September 15, 2007 this is a known bug...legacy dwg is the only option Link to comment Share on other sites More sharing options...
tayrona Posted September 15, 2007 Share Posted September 15, 2007 I switch the surface deviation for 3D solids to 0 (Geometry section of the import dialogue box), and is not necesary to use legacy.... Link to comment Share on other sites More sharing options...
crushdrive Posted September 17, 2007 Author Share Posted September 17, 2007 Thanks very much, for the help it did solve the problem. I'll be using this import most of the time. Link to comment Share on other sites More sharing options...
tayrona Posted September 17, 2007 Share Posted September 17, 2007 How did you solve it? with legacy? or with surface desviation in 0 ? Link to comment Share on other sites More sharing options...
crushdrive Posted September 18, 2007 Author Share Posted September 18, 2007 How did you solve it? with legacy? or with surface desviation in 0 ? __________________ Tayrona http://www.gaestudio.com/ I have not solved the problem because i'm using 3D MAX 06, which dont have a option for a Legacy dwg import or Surface deviation. But on latest version it does have both option in importing curved & arcs. Any way as they say there is an always another way to solved the problem. Thanks very much. Link to comment Share on other sites More sharing options...
