Help with Neon
graphix
I am currently working on a project for a historic theater renovation and am having troubles duplicating the look of neon. I have downloaded and installed neon 1.0 by marc and it does not seem to be casting any light on the signage.
Any help would be appriciated.
Thanks,
graphix
I'm not familiar with the plugin you're referring to, but you probably need to read up on "Radiosity Override" material properties. Check your helpfile.
If you don't have access to the help file for some reason, you basically select the root properties of the material, and change the type from "Standard" to "Radiosity Override", and keep the old material as a sub-material. Then, change the "Luminance Scale" from the default of "0" to 1500, and go from there.
You will need to process the radiosity solution to see the effects. Of course, this is assuming you're in fact using radiosity.
