JPS Posted March 23, 2003 Share Posted March 23, 2003 To whomever can help: I have a rendering in which I want to make the exterior walls of the main building white in orther to differentiate it more distinctly from the rest of the site buildings. I've tried almost everything but the walls still look grey to off white. I've set the ambient, diffuse and specular Blinn shader paramaters to completely white (255 on all RGB). I've even gone as far as checking the self-illumination color box to on and placed a color of pure white and also have made the all the rest of the materials a radiosity overide material with a bleed of 0. The radiosity calculation itself is set to: 75% Initial Quality 2 Refine Iterations On all objects The environment settings are: Global Lighting: Tint=whit Level=1 Ambient=black Logarithmic exposure control with a raised brightness. brightness = 70 contrast = 50 mid tones = 1.0 physical scale = 1500 Both daylight and exterior are checked. Here is the sample. The one thing I've been noticing is that the whiter I try to make the material the more whased out the corners of the building get which to me is an undesired effect. Please any suggestions are certanly appreciated and welcomed. Thanks in advance. J. Link to comment Share on other sites More sharing options...
Wojciech Klepacki Posted March 24, 2003 Share Posted March 24, 2003 Hi JPS, Try to adjust Color Correction checkbox in Environment panel. Use pale colour. The simplest way: check your sun, then go to Modify tab, under Sun Parameters - intesity, dag&drop colour to the Colour Correction probe. It works. rgds, Wojciech Klepacki P.S. Colour Correction should be checked. http://www.cgarchitect.com/forum/filepush.asp?file=Capture_1.jpg Link to comment Share on other sites More sharing options...
jucaro Posted March 24, 2003 Share Posted March 24, 2003 you can also try to lower down the values of color bleed in your Advanced Material Overide. But I think its more on the values of your color corection parameters Link to comment Share on other sites More sharing options...
Wojciech Klepacki Posted March 24, 2003 Share Posted March 24, 2003 Hi, U r right jucaro, but in this case lowering the material bleeding in radiocity overide panel is the second step. Moreover - this step is unnecessary when u want to keep walls white. Colour bleed has visible influence when u want to give ANY colour but white. rgds, Wojciech Klepacki Link to comment Share on other sites More sharing options...
jucaro Posted March 24, 2003 Share Posted March 24, 2003 Originally posted by Wojciech Klepacki: Hi, U r right jucaro, but in this case lowering the material bleeding in radiocity overide panel is the second step. Moreover - this step is unnecessary when u want to keep walls white. Colour bleed has visible influence when u want to give ANY colour but white. rgds, Wojciech Klepacki Yes, but having high values of color bleeding will make a white material catch colors from other materials. Thus, in effect make a white material less whiter Link to comment Share on other sites More sharing options...
JPS Posted March 24, 2003 Author Share Posted March 24, 2003 WOW, thanks a lot guys! Wojciech, dragging and dropping the sun color to the color correction in the environment panel worked like a charm. I would have never been able to figure that one out. Where did you learn that trick? Is there some place where I can get good tuts for things like this? Thanks again. J. Link to comment Share on other sites More sharing options...
Wojciech Klepacki Posted March 24, 2003 Share Posted March 24, 2003 Hi JPS, Practice, practice my friend... Look at the manual (What is disallowed is allowed). Nice to hear that my "trick" helps u solving the problem. rgds, Wojciech Klepacki Link to comment Share on other sites More sharing options...
Wojciech Klepacki Posted March 24, 2003 Share Posted March 24, 2003 What is NOT disallowed is allowed - I mean... rgds, Wojciech Klepacki Link to comment Share on other sites More sharing options...
