how to model dome with turrets
chow choppe
thats going to be a heavy mesh in AutoCAD... if you have it available i'd look towards max / viz or a similar app for modelling the dome elements and then just align them as required to your AutoCAD model.
If it has to be done in CAD i think you need to have a look at the "edgesurf" command and model the domes as surfaces rather than solids. Looking in the help file will explain it better than i can in a few lines.
Give a try to have a star shape. have a fillet radius until satisfied.
Extrude lets say N amount with 10 sements. Apply a FFD4x4 modifier, scale the upper and lower nodes, voilá.
If not, I agree with previous post. Have one piece, a shape lofted through a spline, and have the pivot point of that arranged to your center, make the amount of copies needed.
thanks chad
but the upper portion's arc curve is in continuation with the lower one ( in elevation} . i just hope that u will not see a divison between the upper and lower portion which otherwise has to look like a continuous curve from top to bottom
And "Chiquito" can u put up some screenshots to explain ur methof of modelling it in max
Thanks
thanks chad
thats simply a case of drawing your curves correctly and spend a few minutes drawing it well to begin with, i'm pretty sure chad has just thrown this together quickly with little precise thought as to the shapes used to illustrate the process.
