blotches/splotches in dark areas
spanish pants
if you're using the irradiance, will certainly looks to be the case, the size of the splotches is controlled by the irradiance map resolution (ie the max rate)...the variance in the color of the splotches (ie the quality of the samples) is controlled by hsph subdivs...the blending or smoothing of the splotches is controlled by interp samples.
you could easily remove the splotches by adjusting all 3 of these values
i would start hsph subdivs at 20 (since it has such a tremendous effect on render time) and increase only if absolutely necessary
i would stick with the presets for starters
i would take inter samples up to 100 if necessary before going crazy with the other 2 settings
if you are not already doing it, you should also use some vray light planes to act as fill lights in your windows and doors....it reduces the need for such high quality gi settings
  • 2 weeks later...
Brian,
Just a couple of quick question;
If you are using LWF, would you still get the same problem with the splotches,
And adding vray planes to windows and doors, would lead to other problems of too much light wouldnt it..?
Signed up as well after seeing that link..:D
