Josh1587140445 Posted August 26, 2003 Share Posted August 26, 2003 Does anyone have a solution / reason why VIZ just closes without any warning or option to save. It just started happening today. When I take a brand new object and go to the edit mesh modifier and try to select vertices. That is when it crashes on me. Link to comment Share on other sites More sharing options...
Josh1587140445 Posted August 26, 2003 Author Share Posted August 26, 2003 Ok, now explain this. I can select vertices in a spline and edit it. But once I try to use it on any other objects it will crash the program. This is beginning to piss me off. Link to comment Share on other sites More sharing options...
David Barbarash Posted August 26, 2003 Share Posted August 26, 2003 have you tried an un-install/re-install yet? Could be a corrupt installation for some reason or the result from hte installation of some other unrelated program that is somehow affecting VIZ. If that doesn't work, try ending tasks one by one through your task manager and try to figure out if there is a conflicting program running. Other than that, it could be any number of things, including your graphics drivers somehow. Give these a try if you have time and keep us updated. David Barbarash Link to comment Share on other sites More sharing options...
Josh1587140445 Posted August 26, 2003 Author Share Posted August 26, 2003 Actually that is my next step. But unfortunately I do not have administrative privileges. So I have to wait until tomorrow morning. So in the mean time and I taking everything it home with me to finish. Link to comment Share on other sites More sharing options...
isagreg Posted August 26, 2003 Share Posted August 26, 2003 Have you installed the Service Pack 2 for VIZ 4? Here is the direct link. http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2525179&linkID=2377704 Link to comment Share on other sites More sharing options...
Josh1587140445 Posted August 27, 2003 Author Share Posted August 27, 2003 Well I reinstalled everything and I am still getting the same problem when I go to the Vertex level of an object. And I know it is not the file because I was able to do it at home with no problem. And I am running Windows 2000. And yes, Service Pack 2 has been installed. Link to comment Share on other sites More sharing options...
diablo Posted August 27, 2003 Share Posted August 27, 2003 huummmm.. the last week, I had almost the same problem, but in my case; I couldn't open the new drawings just the old ones. The reason? the service pack was installed in my computer. solution? I had to uninstall the service pack and it worked. I hope this information can be usefull to you and good luck.. Link to comment Share on other sites More sharing options...
Josh1587140445 Posted August 27, 2003 Author Share Posted August 27, 2003 Well service pack 4 has not been installed on the computer. So I do not know what the deal is. It is really pissing me off. Because now I can not even view my work in the viewports. I just get blank screens. Link to comment Share on other sites More sharing options...
abicalho Posted August 29, 2003 Share Posted August 29, 2003 Start VIZ using -H in the command line and choose Software Z-Buffer as your video driver. You do have a very serious Video Card issue, and that's what causing your crashes. I suggest you consult your hardware vendor, and suggest you update your video card drivers ASAP. To start VIZ using the -H command line option, you can do: 1. Start > Run > CMD 2. Go go the folder where VIZ is installed 3. Type: 3dsviz -h Or 1. Right-Click the VIZ icon and choose Properties 2. Add -h (space, hifen, h) after 3dsviz.exe. Example: c:\viz4\3dsviz.exe -h 3. OK all dialogs 4. Start VIZ Hope this helps, Alexander Link to comment Share on other sites More sharing options...
Josh1587140445 Posted August 29, 2003 Author Share Posted August 29, 2003 It was a video card issue. I switched to the Heidi driver. Now it works. Thanks everyone. Link to comment Share on other sites More sharing options...
abicalho Posted August 29, 2003 Share Posted August 29, 2003 Josh, If your hardware was working before, and now it isn't, and you have not performed any software updates, I honestly suggest you replace your video card, or talk to your vendor about it. If you did update drivers, softwares, then I suggest you try uninstalling them or try looking for newer drivers. Your system is still unstable, and it's possible you'll see more problems in the near future. What you did is just "switch to safe more" and now you can keep on working. You didn't solve the problem. Hope it helps, Alexander Link to comment Share on other sites More sharing options...
Psychoscorpic Posted August 30, 2003 Share Posted August 30, 2003 As a related issue: I am unable to Open a model I am busy with. It's a simple shell of a factory, to be composited into a photo. However, I CAN start a new file, and Merge the model into it and work. However I cannot close and open even this new file. Also tried exporting the whole model in 3DS and DXF, as well as the individual objects. Same result each time. Any ideas? Link to comment Share on other sites More sharing options...
abicalho Posted August 30, 2003 Share Posted August 30, 2003 Jephrey, Look at this topic: Autodesk VIZ and W2K SP 4/Hot Fix Issues http://www.cgarchitect.com/ubb/ultimatebb.php?ubb=get_topic;f=6;t=000258 Alexander Link to comment Share on other sites More sharing options...
Psychoscorpic Posted September 1, 2003 Share Posted September 1, 2003 Originally posted by Alexander Esppeschit Bicalho: Jephrey, Look at this topic: Autodesk VIZ and W2K SP 4/Hot Fix Issues http://www.cgarchitect.com/ubb/ultimatebb.php?ubb=get_topic;f=6;t=000258 Alexander Link to comment Share on other sites More sharing options...
Psychoscorpic Posted September 1, 2003 Share Posted September 1, 2003 Thanks, Alexander! I had missed that it also affected XP Pro and not only 2000. Originally posted by Alexander Esppeschit Bicalho: Jephrey, Look at this topic: Autodesk VIZ and W2K SP 4/Hot Fix Issues http://www.cgarchitect.com/ubb/ultimatebb.php?ubb=get_topic;f=6;t=000258 Alexander Link to comment Share on other sites More sharing options...
Zortea Posted October 28, 2003 Share Posted October 28, 2003 Hi everyone... I´ve noticed that in some circuntances, Viz does not want to work... when I use the car paint material into some part of the model, it crashes(´course it warn me that an error accour but didn´t say where is the error) using radiosity it simply does not render and crashes(same warning) If I use a great amount of RPC content, same thing happens... I own a 32Mb video card and my PC is a umble AMD K6 500Mhz with 132Mb RAM... Maybe I should consider a machine upgrade but now it seems just impossible(no ca$h) thanks for the help... Link to comment Share on other sites More sharing options...
JHalton Posted October 28, 2003 Share Posted October 28, 2003 It seems that it is your machines spec. Its quite low. Are the errors on the same file or is it happening all the time? I have had problems with RPC content in the past and I have decided to stop using it all together, IMOP I think RPC is a quick lazy way to get content into scenes, which is detremental to the final look. but again, this is my opinion. Link to comment Share on other sites More sharing options...
Zortea Posted November 3, 2003 Share Posted November 3, 2003 It´s me again... well... after an extensive cleaning of my faithful K6 wich include several files on the HD, SURPRISE!!!! VIZ now runs solid as a rock... as a professor of mine said to me "COMPUTERS DOES NOT BELONG TO EXACT SCIENCES, IT BELONGS TO HIDDEN SCIENCES" and those who work with CG knows this very well... by the way it was the same file I was working... Link to comment Share on other sites More sharing options...
