innerdream Posted September 21, 2007 Share Posted September 21, 2007 I need a good background - any suggestions where to get one? I would like a ocean view. I looked at Modelup and they took their Miami photos down. Model Sketchup, Renderer Cheetah 3D, Photoshop. Link to comment Share on other sites More sharing options...
ipxstudios Posted September 21, 2007 Share Posted September 21, 2007 Here's a stock photo site with free images, just register your name and email address. they are all high res. http://www.sxc.hu/home Link to comment Share on other sites More sharing options...
innerdream Posted September 21, 2007 Author Share Posted September 21, 2007 Thank you sir. Link to comment Share on other sites More sharing options...
jophus14 Posted September 21, 2007 Share Posted September 21, 2007 Go to http://www.morguefile.com Link to comment Share on other sites More sharing options...
innerdream Posted September 21, 2007 Author Share Posted September 21, 2007 That's a good one, thanks. Link to comment Share on other sites More sharing options...
skywalker Posted September 22, 2007 Share Posted September 22, 2007 My suggestion would to carefully match your background to the type of lighting you are using. Since it seems that your lighting is truely bright I would consider softening your shadows and toning done the light. After you have created a more natural mood then look for something that will match your forground and consider the environment as a factor before moving forward. Are you setting up your render engine correctly? I was just looking at your image and theirs seems to be hard indirect and direct lighting. Well good luck and may the force be with you................................... Link to comment Share on other sites More sharing options...
innerdream Posted September 22, 2007 Author Share Posted September 22, 2007 My suggestion would to carefully match your background to the type of lighting you are using. Since it seems that your lighting is truely bright I would consider softening your shadows and toning done the light. After you have created a more natural mood then look for something that will match your forground and consider the environment as a factor before moving forward. Are you setting up your render engine correctly? I was just looking at your image and theirs seems to be hard indirect and direct lighting. Well good luck and may the force be with you................................... I'll have to consider what you have said, as I was using a Spine3d image as my inspiration and their images are stylized not photoreal. As far as the render engine in Cheetah it does not have much in the way of parameters, no soft shadows on the lights as well. I'll keep tweaking though... Link to comment Share on other sites More sharing options...
innerdream Posted September 22, 2007 Author Share Posted September 22, 2007 Here is the background I selected - pre photoshop. Link to comment Share on other sites More sharing options...
