pwharton Posted September 22, 2007 Share Posted September 22, 2007 I have set up a file to render with mental render, I have set up the custom UI to Mental render. Added a Daylight system to the scene and set it to MR Sun and Sky. At times when I am rendering I get this message; “MSG 0.0 error: Shadow generator "Unknown Shadow Generator" on light "Sun02" is unsupported (mental ray only supports raytraced and shadow maps). Using raytraced shadows.” Its not every time I render, just sometimes…. IWhen you go to the modify panel to switch shadow maps there is no shadow types shown under the MR sun or sky. Am I missing something? What does this message mean? And where do you go to find out what the messages in the error panel means? Link to comment Share on other sites More sharing options...
Thiago de Andrade Posted September 23, 2007 Share Posted September 23, 2007 you probably have another sun applied to your scene. Check the object list. Link to comment Share on other sites More sharing options...
Justin Hunt Posted September 23, 2007 Share Posted September 23, 2007 It happens when the default shadow generator is set to "Advanced Raytrace" which Mentalray doesnt support. Mental will automatically change it to raytrace, so its something that you can quite safly ignore. JHV Link to comment Share on other sites More sharing options...
pwharton Posted September 24, 2007 Author Share Posted September 24, 2007 Thank for the replies, where would Igo to change the default setting? Link to comment Share on other sites More sharing options...
Milatonka Posted September 24, 2007 Share Posted September 24, 2007 I think it Just keeps the last used? Link to comment Share on other sites More sharing options...
Justin Hunt Posted December 2, 2007 Share Posted December 2, 2007 Sorry the resarect this thread but I may have a solution If you go the the "custom UI and Defalts" in the customization menu there is a defaults for Mentalray a DesignViz mentalray, both of these will change the default shadow generator to Raytrace. Stumbled across this a few days ago JHV Link to comment Share on other sites More sharing options...
