very very urgent
sanmb
I understand why you're at a loss, coming from 3ds Max. Rhino objects are generally not parametric. Some commands you can research and practice with: Scale, Scale2D, Scale1D. Use the scale command for precision adjustments. Stretch is also a tool you should look at.
Obviouslly all the above.
If the question is for lack of even trying anything... well I guess it will show in your work. Now, if it its because for some reason you do not have a modifier parametrical chance, try placing an object that does have it, snap it and have it traced. Scale original to that one (polymesh, editpoly).
Could you place a screen grab?
