Lhanh29 Posted September 26, 2007 Share Posted September 26, 2007 Hello everyone, Now i have a problem with rendering big size!! How can i set up one view with high solution, big size(2mx4m).I have been rendered but detail to be broken image(unclear) Please hepl me.Thanks Link to comment Share on other sites More sharing options...
jophus14 Posted September 26, 2007 Share Posted September 26, 2007 Use the "VRImg to OpenEXR Converter" through Vray. Link to comment Share on other sites More sharing options...
chow choppe Posted September 26, 2007 Share Posted September 26, 2007 Use the "VRImg to OpenEXR Converter" through Vray. whats thst can u throw some more light on it Thanks Link to comment Share on other sites More sharing options...
edgy_k Posted September 26, 2007 Share Posted September 26, 2007 He certainly talks about vrimg2exr utility wich allows to convert vrimg files to more usable exr ones. Link to comment Share on other sites More sharing options...
Lhanh29 Posted September 27, 2007 Author Share Posted September 27, 2007 Use the "VRImg to OpenEXR Converter" through Vray. Sorry, can you show me how to do with that.Thanks Link to comment Share on other sites More sharing options...
gfa2 Posted September 27, 2007 Share Posted September 27, 2007 You need to use the Vray frame buffer (instead of the max frame buffer) and then choose to render to Vray's vrimg file format. That process will write the image to a file as it renders it, saving your RAM. Then you will either use the vrimg2exr tool to convert to exr (that can be opened in Photoshop) or you can view the vrimg in max by clicking 'File' then 'View image file' in max. Link to comment Share on other sites More sharing options...
chow choppe Posted October 3, 2007 Share Posted October 3, 2007 two questions When i use vray frame buffer the bucket size gets very small how can i make it big and secondly where can i find this vrayimg to exr utility Link to comment Share on other sites More sharing options...
jophus14 Posted October 3, 2007 Share Posted October 3, 2007 Sorry for the late reply. Check the attachment for the Bucket Size location. To get to the OPenEXR..........Go to Start on your computer, All Programs, ChaosGroup, Tools, and then VRImg to OpenEXR Converter. Link to comment Share on other sites More sharing options...
jophus14 Posted October 3, 2007 Share Posted October 3, 2007 When you open the VRImg to OpenEXR Converter it'll look like the attachment. After the line that reads C:\Program Files\Autodesk\Viz2007 or Max\Plugins\tools> type: vrimgexr(space)C:\name you want file to be.vrimg(space)C:\name you want file to be.exr(space)-sRGB Example: vrimgexr C:\InteriorHall.vrimg C:\TestRender.exr -sRGB I would recommend NOT using spaces inbetween the file names like I did in my example. When the file is finally saved to the destination that you picked it'll show up as a EXR file. Double click this file and Photoshop should open. Resave the file as a Tiff or Jpeg once in Photoshop. If anyone sees anything wrong or indifferent with the way I explained this method of using the OpenEXR, please add to this post. It's quite simple after you do it once. Link to comment Share on other sites More sharing options...
Lhanh29 Posted October 25, 2007 Author Share Posted October 25, 2007 thanks for your advise.jophus14. Link to comment Share on other sites More sharing options...
dagor Posted October 25, 2007 Share Posted October 25, 2007 Use Leley`s script vrimg2exr_GUI. It give you graphic interface for vrimg converter. If you set your bucket size bigger - it takes more memory. Link to comment Share on other sites More sharing options...
Lhanh29 Posted October 27, 2007 Author Share Posted October 27, 2007 thanks, i will do it following your idea. Link to comment Share on other sites More sharing options...
arquimagen75 Posted October 27, 2008 Share Posted October 27, 2008 sorry I am new here but i tryed to open de vrmig converter but it doesnt work when I make double click on the vrimg2exr.exe Link to comment Share on other sites More sharing options...
