ctk111 Posted September 26, 2007 Share Posted September 26, 2007 I don't understand why I'm not getting any reflectance from my glass mat when there are other objects behind it. For instance, the attached image has a glass mat applied in the window panes. In the lower left and upper right windows you can see the reflection is working, but in the lower right and upper left windows, where there are objects behind the window, the reflection doesn't appear to be working. My settings are attached. Thanks. Link to comment Share on other sites More sharing options...
Koper Posted September 27, 2007 Share Posted September 27, 2007 you need to remember that if there is allot of light behind the window then it wont reflect that much, and you need something infront of the window to see its reflection. check also your subdivs of the reflection slot, less is less Link to comment Share on other sites More sharing options...
