djohnson129 Posted September 27, 2007 Share Posted September 27, 2007 Hello, I'm pretty much finished with this project. I just need to find a good image for the environment and maybe add a window frame to the rectangle window above the two chairs. Does anybody have any final suggestions on what to add for the final renders? Do you like the camera positions I have? In Test22 I'm going to pan the camera a tiget to the left. Thank you for your input ;D Link to comment Share on other sites More sharing options...
Ernest Burden III Posted September 27, 2007 Share Posted September 27, 2007 Its a picture about un-even lighting. Re-think the sun angle and introduce some interior lights. Link to comment Share on other sites More sharing options...
Aaron2004 Posted September 27, 2007 Share Posted September 27, 2007 Yeah...I agree, you need interior lights. Right now the rendering looks slightly depressing...like the power went out or something. Link to comment Share on other sites More sharing options...
djohnson129 Posted September 27, 2007 Author Share Posted September 27, 2007 Thank you for the help The evenness of light has been something I couldnt get right from the beginning. Where do you have in mind for the interior lights? Above the stairs? Are you speaking of spot lights or like a directional light going downwards just to brighten up everything? Link to comment Share on other sites More sharing options...
Devin Johnston Posted September 27, 2007 Share Posted September 27, 2007 Everything in shadow needs to be brighter but the one thing that's hurting your image the most is your background. If you don't have a good image then just go with a white background, the one you’re using just doesn’t look good. Link to comment Share on other sites More sharing options...
Koper Posted September 27, 2007 Share Posted September 27, 2007 all of the above, and i would make the floor tiles much smaller and mabye a bit lighter than it is now, thinking about it, maybe the carpet texture as well Link to comment Share on other sites More sharing options...
djohnson129 Posted September 28, 2007 Author Share Posted September 28, 2007 Thanks again for your help. The first thing I worked on was the shadows; you guys agreed that they be lighter, so I tried doing that so I increased the softness by 15 units. I wasnt sure if thats what you meant or if I needed to changed the actual color of the shadow to a lighter shade. Well I couldnt find the setting that changes shadow color for the daylight system so I just changed the softness. So then I tried using a background image and it obviously looked horrendous (first time trying it), so today I'm going to spend some time in photoshop to make the perspective fit better and perhaps model a deck just outside the windows. O and I also changed the tile size ;D My questions right now are: did you guys want me to change the actual shadow color to a lighter shade? If so, how can I using the daylight system? Also, I found tutorials showing how to load an environment map but those renders looked really bad and so I figure those are just bad tutorials. Does anybody have a more professional tutorial for putting environment maps in the scene? The tutorial I found suggested using a spherical map but it just looks so distorted. If you read all of that then thanks a ton! :DDD Link to comment Share on other sites More sharing options...
andreg Posted September 28, 2007 Share Posted September 28, 2007 Here's a quick fix in photoshop. hope you don't mind Link to comment Share on other sites More sharing options...
manta Posted September 28, 2007 Share Posted September 28, 2007 Balconies would make it seem much more real... Link to comment Share on other sites More sharing options...
djohnson129 Posted September 29, 2007 Author Share Posted September 29, 2007 Ok so I finally got the backgrounds in. Each one is a different look and feel, so please let me know which camera view is best and what I need to change about it. I may have went overboard in photoshop so if they look bad I'd be happy to hear about it ....and they're small cuz I had to resize them to fit the KB limit :/ Thanks yous! Link to comment Share on other sites More sharing options...
manta Posted October 10, 2007 Share Posted October 10, 2007 Sorry if I'm reading that wrong...but is that a door that people open and dive into the water ? Link to comment Share on other sites More sharing options...
kiittea Posted October 17, 2007 Share Posted October 17, 2007 My 2 cents - correct your camera angle first. I would be helpful in adjusting the perspective of the bg Link to comment Share on other sites More sharing options...
djohnson129 Posted October 18, 2007 Author Share Posted October 18, 2007 Here's the finished one....or the farthest I got. There's a thread in the Finished Works forum I've been posting in, I havent been on this one in a while. Link to comment Share on other sites More sharing options...
