Jeff Mottle Posted September 28, 2007 Share Posted September 28, 2007 I'm not sure how many of you use Remote Desktop, but I found a solution for a problem I have had for a number of years. If you connect remotely with RDP, the default color bit depth is 16bit. This obviously have the effect of banding images on the remote system. There is a setting you can change however to increase this default to 24bit. 32 bit is still not supported, but 24 is still much better than 16. http://osdir.com/ml/network.rdesktop.user/2006-01/msg00001.html Link to comment Share on other sites More sharing options...
Koper Posted September 28, 2007 Share Posted September 28, 2007 thanx ALLOT Jeff, now I'll be able to view renderings a bit better and not wait till its finnished to judge if everything is A.OK Link to comment Share on other sites More sharing options...
