Pectabyte Posted September 29, 2007 Share Posted September 29, 2007 So I've been using OnyxTREE and I have messed around with the wind parameters. Looks nice but how do I animate the tree being blown in the wind and then export the tree and its animation to 3DS max 9? Link to comment Share on other sites More sharing options...
gfa2 Posted September 29, 2007 Share Posted September 29, 2007 The max plugin for Onyx (I think it's called TreeStorm) has wind settings. So you build a tree in the Onyx program then save it to the Onyx file format and use the max plugin to place the tree in the scene. Then you use the plugin to modify the settings and activate the wind if you want. Link to comment Share on other sites More sharing options...
Pectabyte Posted October 1, 2007 Author Share Posted October 1, 2007 I have tree storm 5 and it doesn't look like there is any kind of plug-in. Just lots of pre-made trees. Where would the plugin be and if I don't have it is there a place I can download it? Link to comment Share on other sites More sharing options...
gfa2 Posted October 1, 2007 Share Posted October 1, 2007 Tree Storm is the plugin. In max or VIZ you'll find it under the Create tab and then under the drop down menu where it says Standard Primitives, choose Tree Storm. Link to comment Share on other sites More sharing options...
Pectabyte Posted October 2, 2007 Author Share Posted October 2, 2007 Umm... It isnt installed because I don't have it. I have treestorm but it is only a bunch of premade trees. There is no plugin. Link to comment Share on other sites More sharing options...
Matt Clementson Posted October 2, 2007 Share Posted October 2, 2007 Sounds like you either haven't installed correctly or haven't gotten the full install. Onyx comes in two parts the creator/editor - called Tree Classic, this runs externally to MAX. And a small .dlo file that's the MAX plugin - TreeStorm - that you need to manually copy into MAX's plugin directory. Once installed it lets you place the trees that you create in Classic into your MAX scene. It also has the wind controls that let you animate the tree. Link to comment Share on other sites More sharing options...
Pectabyte Posted October 13, 2007 Author Share Posted October 13, 2007 Ohhh. Okay it looks like Treestorm plugin is NOT compatible with Max9. Damn Bummer... I found the .dlo i put it in the plugins folder but the initializer terminates and doesn't load max when trying to load treestorm.dlo Link to comment Share on other sites More sharing options...
gfa2 Posted October 14, 2007 Share Posted October 14, 2007 There is a specific version for max 9. They had to recompile it for max 9 so they are charging for that. Link to comment Share on other sites More sharing options...
