need help in rendering workflow
cupsster
Since you're using Vray, most likely your output size under Max's common settings is different (as you usually want to keep this really small) from the one you set up in the Vray frame buffer. For some reason ( at least I've found this) they need to be the same when doing a region render.
There's a "use max settings" check box in the VFB for that..
