vdrug Posted October 4, 2007 Share Posted October 4, 2007 My work is almost done but it seem everything is go away. The computer suddenly restarting while i'm working with sub object in Max, and then i cannot re_open it , there is a message "File open failed" . Can you please show me something i can do to recover this file (project). Thanks.! Link to comment Share on other sites More sharing options...
Nic H Posted October 4, 2007 Share Posted October 4, 2007 1. autoback 2. merge into new file 3. .......nothing you can do Link to comment Share on other sites More sharing options...
clauco Posted October 4, 2007 Share Posted October 4, 2007 Try merging the entire scene in a new one as Nicnic said. If that doesn´t work you should try merging object by object to a new scene until you find the object which is making the file to crash. Good luck! Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted October 4, 2007 Share Posted October 4, 2007 this is a good time to reiterate the why you should do a save as, and the increment the file 01, 02 ,03, etc.. learning the hard way is a bitch. that being said, before you do anymore work, check your autoback directory, and see if there is a version in there that is healthy. i keep a shortcut to my autoback directory specifically for this reason. hard drive space is cheap. really cheap when compared to the number of hours that are potentially lost when a file corrupts. Link to comment Share on other sites More sharing options...
FlyinHawaiian Posted October 4, 2007 Share Posted October 4, 2007 We've got some proprietary scripts at Focus360 that intelligently iterate your saves, but script spot also seems to have some good options. I haven't personally tested this one, but it looks very promising: http://www.scriptspot.com/3ds-max/backup-save-script Good luck with your crashed file! We've all been there and feel your pain. The moral of the story is to not let yourself get burned again. Back it up! Aloha, Joel Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted October 6, 2007 Share Posted October 6, 2007 also, i had a file that kept crashing today. i couldn't tell why it was crashing, but remembered that i had the site set as a xref scene. i simply renamed the xref'd scene to something else, and the file opened without a problem. i then relinked the scene, and everything was a-okay. i am not saying that is your problem, but just thought i would mention it on the slim chance that it was. Link to comment Share on other sites More sharing options...
vdrug Posted October 10, 2007 Author Share Posted October 10, 2007 Thanks you so much for helping me,the project is done, topic closed! Link to comment Share on other sites More sharing options...
mmowry Posted October 10, 2007 Share Posted October 10, 2007 We've got some proprietary scripts at Focus360 that intelligently iterate your saves, but script spot also seems to have some good options. I haven't personally tested this one, but it looks very promising: http://www.scriptspot.com/3ds-max/backup-save-script Good luck with your crashed file! We've all been there and feel your pain. The moral of the story is to not let yourself get burned again. Back it up! Aloha, Joel We use this script here at work and it's SAVED our as*es more times than I can count. You have to be VERY dilligent about cleaning out the backup subfolder, as it creates a backup quite frequently (100+ / day?) and if your MAX file is sizeable, you can quickly eat up GB of server space. -Michael Link to comment Share on other sites More sharing options...
maumau Posted August 13, 2008 Share Posted August 13, 2008 mike, how do you specify the folder where the backup files will be saved? i find the script looking for the folder, but i haven't been able to modify it. Link to comment Share on other sites More sharing options...
Tommy Burns Posted August 14, 2008 Share Posted August 14, 2008 Thanks you so much for helping me,the project is done, topic closed! Thats great but any chance you could let us know what you did to fix it in the end??? It might help someone else on here with a similar problem Link to comment Share on other sites More sharing options...
A.Mitov Posted August 14, 2008 Share Posted August 14, 2008 I have also recovered a corrupted file just by trying to open it again and again. Some times it takes up to 20 opens. That worked for me while doing a recent project. Link to comment Share on other sites More sharing options...
jintu Posted July 13, 2009 Share Posted July 13, 2009 Try to copy the file then paste to the same directory. Link to comment Share on other sites More sharing options...
