nivvu Posted October 4, 2007 Share Posted October 4, 2007 hi all. here iam having a problem with direct light in vray.. i want to give a volumetric effect to direct light in vray so tht it makes sense tht light is passing from an window... bt vray renderer doesnt suport volumertic light i guess...... please adivse me how to give a volumetric light effct in vray ........ thanks in advance nivas Link to comment Share on other sites More sharing options...
PAWUK Posted October 4, 2007 Share Posted October 4, 2007 You mean something along the lines of this....... http://www.evermotion.org/index.php?unfold_exclusive=64&unfold=exclusive Link to comment Share on other sites More sharing options...
brentwatanabe Posted October 4, 2007 Share Posted October 4, 2007 any idea if that would work for Vray for Rhino? Link to comment Share on other sites More sharing options...
clauco Posted October 4, 2007 Share Posted October 4, 2007 hi all. here iam having a problem with direct light in vray.. i want to give a volumetric effect to direct light in vray so tht it makes sense tht light is passing from an window... bt vray renderer doesnt suport volumertic light i guess...... please adivse me how to give a volumetric light effct in vray ........ thanks in advance nivas As far as I know, you could only get a volumetric effect in vray using standard lights with shadows in shadowmap mode, obviously checking it parameters for volumetric light effects. Good luck! Link to comment Share on other sites More sharing options...
nivvu Posted October 5, 2007 Author Share Posted October 5, 2007 hi Arqmac... thanks for the post reply.... yesterday itself i was gng through shadow settings and i got it........ anyways thanks a lot for the reply..... cheers nivas Link to comment Share on other sites More sharing options...
JNoy Posted October 23, 2007 Share Posted October 23, 2007 I was working with the direct light for volumetric effects, and noticed that it seems to invert when using the VrayPhysicalCamera. I made the light pink, and got green results. When I made it brighter, the scene got darker. I had to crank the light multiplier up to 200 to see it in the scene, and when I did it was basically a solid wall of blue-grey. I've gotten it to work perfectly fine without the physCam, so I'm guessing that it's simply incompatible? Is this a known issue, or do I just have improper settings? Link to comment Share on other sites More sharing options...
jeandelessard Posted October 31, 2007 Share Posted October 31, 2007 is it for a still or for animation... if it's for still image... fake it with PS. Link to comment Share on other sites More sharing options...
JNoy Posted October 31, 2007 Share Posted October 31, 2007 This would be for animation and stills, though I'm trying to avoid a lot of post work and compositing. I made an image that shows the problem I'm having. All the renders are using the physical camera, except the last one. Link to comment Share on other sites More sharing options...
dagor Posted October 31, 2007 Share Posted October 31, 2007 vray dosn`t work with volume effect. you can render volume pass for compositing with scanline render. Link to comment Share on other sites More sharing options...
JNoy Posted October 31, 2007 Share Posted October 31, 2007 The volume light seems to work fine in VRay, though- just not with the VRayPhysicalCamera. That last image I posted shows how it looks when rendered in Vray through the perspective viewport. The color and different effects of the volume light are perfect until I use the physcam, when everything seems to invert itself. Link to comment Share on other sites More sharing options...
dagor Posted October 31, 2007 Share Posted October 31, 2007 you`ll have more control on it in postproduction stage. it realy fast to change color or transparency or add glow on it in post. but if you don`t like how does volume look`s in render - you need to rerender it. Link to comment Share on other sites More sharing options...
