chow choppe Posted October 6, 2007 Share Posted October 6, 2007 hi all the image says it all can u help me Thanks haneet Link to comment Share on other sites More sharing options...
chow choppe Posted October 8, 2007 Author Share Posted October 8, 2007 no replies? Link to comment Share on other sites More sharing options...
Nic H Posted October 8, 2007 Share Posted October 8, 2007 Select the main big polys, then Ctrl - I to invert selection? Or is teh model more complex than your image? Link to comment Share on other sites More sharing options...
Matt Clementson Posted October 8, 2007 Share Posted October 8, 2007 Or windowing around each 'strip' with CTRL held down Link to comment Share on other sites More sharing options...
msalah78 Posted October 8, 2007 Share Posted October 8, 2007 select desired faces only once and save them as "named selection" give them any name you like , and from now on whenever you are in on the "face" sub-object you can call them back easily from the named selection set you choosed. Link to comment Share on other sites More sharing options...
anvaraziz Posted October 8, 2007 Share Posted October 8, 2007 its a trick.... after u chamfer the edges... do an invert selection... now hold ctr + clik the face selection button under comand panel.. u got me ? it works,,,, i use this trick everyday,, Link to comment Share on other sites More sharing options...
chow choppe Posted October 9, 2007 Author Share Posted October 9, 2007 hi anvar i was looking for ur trick only but i think if i followed ur steps i was left with all faces selected except for the one in the centre all other faces including the big ones and smaller chamfered ones are selected i think u missed a step somewhere can u put up some screenshots or write in more detail Thanks Link to comment Share on other sites More sharing options...
