Matt Sugden Posted October 9, 2007 Share Posted October 9, 2007 hi, a client has asked me to work on an interesting animation project for a new build, and part of this animation he wants me to show the old building being demolished. I'm currently exploring ideas to tackle this, but the emphasis needs to be simple, fast to implement, yet effective. I use max as my modeling package, any ideas on good ways of doing this? I'm guessing some form of particle system perhaps? or rigid body type thingy? Your comments would be appreciated. Cheers Matt Link to comment Share on other sites More sharing options...
Arnold Sher Posted October 9, 2007 Share Posted October 9, 2007 digimation grow... reverse the sequence, that is probably the fastest way of doing it... Link to comment Share on other sites More sharing options...
alrawli Posted October 9, 2007 Share Posted October 9, 2007 You might be able to use reactor within max to do building demolitions. Also theres this http://www.buscatube.com/play/youtube/3ds/tag1/KmHGxWjydq8/building-demolition-in-3ds-max-video-1-of-2/ Looks a bit basic and needs some other pluggins but it wouldnt take much work to look good. Link to comment Share on other sites More sharing options...
Guest Brandon_01 Posted October 9, 2007 Share Posted October 9, 2007 http://www.commonpointinc.com/products/project4d/project4d.asp Otherwise you could dissolve between stills showing demo in phases. With limited time, I wouldn't worry about realism or pretty explosion fx - just get the point across. Link to comment Share on other sites More sharing options...
Matt Sugden Posted October 9, 2007 Author Share Posted October 9, 2007 Well, at the moment I'm thinking of just using simple bomb modifier, as i think that might be enough, but I'm at a loss as to stop the fragments falling through the ground plane, as I'd like the building blocks to explode, but then come to rest on the ground. I assume some form of collision type thing? Is this a job for reactor, I've tinkered with this a little in the past, but I must confess to completely forgetting how I did it in the past. Any ideas? cheers Link to comment Share on other sites More sharing options...
Thox Posted October 9, 2007 Share Posted October 9, 2007 You need a Deflector Space warp on the ground plane, which you can find under the create menu>space warps>deflectors. A standard deflector should do the job nicely. Regards Thox Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted October 9, 2007 Share Posted October 9, 2007 as a side note, have you discussed with your client exactly what they mean by the building being demolished? if i were marketing a new project, the last thing i would want is an implication that the building was being destroyed by a bomb or missle. if i had to guess, i would invision more of an implosion like an implosive profesional would do, or, not as elegant, but a dismantle in the method a wrecking ball might do. Link to comment Share on other sites More sharing options...
Matt Sugden Posted October 9, 2007 Author Share Posted October 9, 2007 Sure, I appreciate what you are saying about making a building looking blown up with bombs etc!! I know exactly what my client wants, he's after a traditional demolition effect. I was merely talking about using the bomb modifier as way to try and simulate the collapsing and imploding characteristics simply which it seems it would do o.k. from my quick prototypes. More info on how the deflector planes work would be very much appreciated though. Cheers Link to comment Share on other sites More sharing options...
Nic H Posted October 10, 2007 Share Posted October 10, 2007 sounds like an interesting project mate, be sure to post up the destruction bit when you are done! Link to comment Share on other sites More sharing options...
Matt Sugden Posted October 17, 2007 Author Share Posted October 17, 2007 Could anyone give me a little more detail on how the standard deflector plane would work with the bomb modifier, to get a collision effect? Cheers. Matt Link to comment Share on other sites More sharing options...
