Memory compatability question
Hi all,
I just got a new pc its a quad core Q6600. its running vista 32 now but I will install xp 64bit. it currenty has two 1gb sticks and want to bring that up to 6gb total. so the question is if this memory I selected http://www.newegg.com/Product/Product.aspx?Item=N82E16820178163 will work with what I currently have installed?. any help would be appreciated as I dont know a whole lot about this. I also attached my current memory specs.
thanks
That's not necessarily correct, but with an Acer computer... you'll need to check the docs for the system, cause who knows what the heck they put in there. Many motherboards will support 2x1GB + 2x2GB so long as you pair them correctly.
It's hard to believe to those people who really good in talking or typing an answer but knowing nothing.
I tell you what... why don't you buy 2x-2gb and put it in your PC. Let us know what will happen. Tell us also if your PC can read a 6gb memory stick. Anyway after a 10 long yrs experience in PC my comments is just only a suggestion. If you don't want my suggestion it's up to you. ;)
What I object to is you making statements in terms that suggest absolute conviction, when you may be wrong. Telling a guy he can't combine 2GB and 1GB DIMMs when you don't know what his MB is, telling another guy he needs SLI to drop his render times - that kind of thing isn't helpful and with your vast knowledge you should know that.
  • 3 weeks later...
well I finally got the new memory installed.... and it works!!! vista is running with no apperent problems. vista is reading 3326 of ram and the bios is reading the full 6gb.
got another problem now, as Im trying to get rid of vista and install xp 64 im getting the BSOD at the install screen right after it starts loading the drivers. anyone got any suggestions? theres only one drive in the pc and it is partitioned if it matters at all.
thanks
Try the installer without the new 4gb? :)
I did but it didnt work. ive been doing some reading and it looks like I need to provide the harddrive driver files when the windows setup is running but the thing is that it prompts me for the files and this pc came with no floppy drive. ive tried the usb ports and the flash card reader but it will not read those. how can I get arround this without buying a new floppy drive?
darn.... I have an old computer and tried to use its floppy drive but that floppy uses one of those old wide ribbon cables. im just going to have to get a new one which annoys me because im going to have to pay something like 40 bucks for it....
thanks for the help guys :)
