cullen Posted October 9, 2007 Share Posted October 9, 2007 Hello all, I am doing my first Master Plan/Site Plan and have a couple texture questions. I have always struggled with a realistic grass so I usually fix it in photoshop. unfortunately I need to take about 15 views and will not have time to "doctor" the image. Grass: I would like the grass to appear as if it was mowed 2 different directions. (like a baseball field) I have used displacement in the past for due to the size and time constraints I don't have that as an option. Any suggestions? Water: The next texture I am trying to figure out is water. This will be my first time to ever render a pond so I don't even know where to start with this. My overall goal is not to achieve a "photo realistic" rendering but more of a "pixar-ish" style. It will be used for a Schematic Presentation. Thanks for the help, crw Link to comment Share on other sites More sharing options...
Rendermedia Posted October 10, 2007 Share Posted October 10, 2007 Hi For grass, I would opt for a nice looking texture, simply duplicate the layer in Photoshop and create your own lawnmower lanes quick and easy, for bump map use a small noise map set to Fresnel, its an old trick I use, and you will be surprised just how close you can get to the view without it showing up to bad, For water, If you are using max standard renderer, I would use a raytrace reflection with some animated noise on it if it’s a sequence, Brazil, use Glass material, or Advanced material and set to translucent, remember to turn off receive shadows & cast shadows on the water object Again a little noise bump V-Ray, don’t know never used it, but judging by the quality of some of the renders an excellent way to go. Cheers Mark Link to comment Share on other sites More sharing options...
cullen Posted October 10, 2007 Author Share Posted October 10, 2007 Thanks for your reply Mark. Unfortunately I won't have the time to do photoshop touchup due to the amount of views needed. I have using V-Ray as my render engine. Thank you for the tip on the noise map. I'll definitely give that a shot. Unfortunately I'm still cleaning up the AutoCAD file. It's in pretty bad shape. thanks, crw Link to comment Share on other sites More sharing options...
Rendermedia Posted October 10, 2007 Share Posted October 10, 2007 Hi Cullen With regards to Photoshop I meant for you to create the texture and then apply that to the lawn, I think an imgage map should work well for you as opposed to real grass Kind Regards Mark Link to comment Share on other sites More sharing options...
cullen Posted October 10, 2007 Author Share Posted October 10, 2007 Thanks for the clarification. I will try that. I've had a problem finding a grass that will tile nicely thought. Thanks, crw Link to comment Share on other sites More sharing options...
mfured20 Posted October 11, 2007 Share Posted October 11, 2007 i saw this site earlier for doing the grass, im not sure if it will work for the cross-hatching you are looking for, but it might help - http://www.cgarchitect.com/vb/11207-vray-displacement-grass.html also, when it comes to water, i tend to just kinda create a glass material with a little color to it, and i add a noise filter to the bump channel. this works pretty well, as long as there are no fountains or anything to disrupt the surface. good luck! Link to comment Share on other sites More sharing options...
