Roest Posted October 12, 2007 Share Posted October 12, 2007 Hi. i"m working on an animation with 2000 frames. I use a precalculated irradiencemap (from file) i do not use multipass. Why does vray an extra prepass before rendering? This cost me about 5 min!! x 2000 :S Someone knows why? as far as i know i don't use any materials with interpolation... Link to comment Share on other sites More sharing options...
JamesTaylor Posted October 12, 2007 Share Posted October 12, 2007 when you use interpolation it causes an extra pass, have you checked every scene material?? Link to comment Share on other sites More sharing options...
Roest Posted October 12, 2007 Author Share Posted October 12, 2007 Thanks for the reply james, I do not use interpolation myself, I've checked the materials i've imported. But i will check again for sure. Is this the only way vray puts in an extra pass? EDIT This extra pass is only calculated if i use an irradiancemap "from file". If i render the same image with a new "single file" irradiance map and light cache there is no extra prepass.... Link to comment Share on other sites More sharing options...
Chewbacca Posted October 12, 2007 Share Posted October 12, 2007 Not sure if this will help....... Try downloading the The VRay Automator v1.0 [iNTERFACE] Maxscript. http://www.metinseven.com/goodies/nl/ Handy tool for globally controling lights, and VRAY material settings. You may have a material checked to use interpolation, the tool allows you to change all settings at once, and maybe will change one you are missing or might not see. Link to comment Share on other sites More sharing options...
Roest Posted October 13, 2007 Author Share Posted October 13, 2007 THanks chewbacca! this tool seems quiet handy! I already found the material with the interpolation on, but it took me more than an hour to find this material...after i unchecked this the render time is about 30% well , next time i will use this tool! Thanks again Link to comment Share on other sites More sharing options...
ShUvR0 Posted January 25, 2011 Share Posted January 25, 2011 many many thanks....I faced same problem...But script rockz...My problem solved... Link to comment Share on other sites More sharing options...
