iamnoel Posted June 7, 2003 Share Posted June 7, 2003 Just wanted to ask whether it is possible to have a LAN, render a single still image, I mean assign 3 computers to output 1 image. I was hoping to achieve a multi threading, distributing the work load of rendering of 1 image to several machines. Or is network rendering in Viz 4 specifically designed for animations only? thanx any help is apreciated. iamnoelr Link to comment Share on other sites More sharing options...
quizzy Posted June 7, 2003 Share Posted June 7, 2003 In Viz4 its called region net render.. Link to comment Share on other sites More sharing options...
iamnoel Posted June 11, 2003 Author Share Posted June 11, 2003 thanx quizzy i manage to do it now Link to comment Share on other sites More sharing options...
abicalho Posted June 12, 2003 Share Posted June 12, 2003 Hi Blaz, Region Net Render ships in MAX 5 as a sample on the 2nd CD. Alexander Link to comment Share on other sites More sharing options...
blaz Posted June 12, 2003 Share Posted June 12, 2003 Hi, any posibility to do that in max? thanks, Link to comment Share on other sites More sharing options...
blaz Posted June 12, 2003 Share Posted June 12, 2003 hi alex, thanks for your info, I'll check it out. Link to comment Share on other sites More sharing options...
quizzy Posted June 13, 2003 Share Posted June 13, 2003 And for a very nice region net render (it f@#$%ing rules!!!) go here: http://magicm.cgcommunity.com/ the best i've seen (I also found a region net render on the max4 cd's) Link to comment Share on other sites More sharing options...
abicalho Posted June 13, 2003 Share Posted June 13, 2003 I'm very disappointed. This is a copy of my script, with variables renamed and features added. Copying code and enhancing it is acceptable, but at least acknowledge the source. This guy is not doing it, he said it's all his own. Put this script side by side with RNR and look for similarities. You'll find way too many for it to be a simple coincidence. Also, this script ships with Autodesk VIZ, 3dsmax 5 and the Design Extension, so it's copyright of Autodesk/Discreet and cannot be redistributed/modified without agreement. I'm contacting my manager and have notified him of it. Someone (maybe myself) will be contacting Martin specifically about it soon. Alexander Link to comment Share on other sites More sharing options...
quizzy Posted June 14, 2003 Share Posted June 14, 2003 OOPS.... didn't know that.... well.... didn't know that.. I've looked at the code ofcourse, and at the source of the RNR that ships with MAX4 and find it very similar indeed.. well its not very nice he didn't mention the source, I always do that... ( I've only modified 2 existing scripts but still....) Link to comment Share on other sites More sharing options...
