Stephen Thomas Posted October 15, 2007 Share Posted October 15, 2007 Has anyone ever had the problem where you lose the ability to enter transforms as an offset instead of absolute? I can still do it if I open the floating transform type-in toolbar, but not by clicking the triangle at the bottom. Can't figure out why it does it or how to fix it, may have pressed a hotkey by mistake or something. Link to comment Share on other sites More sharing options...
alrawli Posted October 15, 2007 Share Posted October 15, 2007 Is it the movement gizmo your talking about? Link to comment Share on other sites More sharing options...
Stephen Thomas Posted October 15, 2007 Author Share Posted October 15, 2007 Is it the movement gizmo your talking about? No, when i select an object and click on move or rotate or whatever, I can usually click on the triangle at the bottom of the screenshot below to toggle between entering absolute coordinates or offset coordinates. But for some reason the boxes just remain greyed out and i have to use the type-in toolbar above. Link to comment Share on other sites More sharing options...
alrawli Posted October 15, 2007 Share Posted October 15, 2007 Ah right it get you, ive tried a few things but cant seem to recreate your problem. Do you have a copy of your UI saved out? maybe reloading this would fix it. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted October 15, 2007 Author Share Posted October 15, 2007 It's ok, it seems to have sorted itself! Maybe just a glitch. Link to comment Share on other sites More sharing options...
Gus_Rayvus Posted October 15, 2007 Share Posted October 15, 2007 next time click the triangle by what you have underlined to toggle your mode type-in. Link to comment Share on other sites More sharing options...
